Hi Derek,
The scaling doesn't necessarily need to be 1:1. Other ratios would just be like having a different number of counts/rev on the encoder.
KFLOP Encoder inputs are limited to 1MHz post-quadrature counts per second.
7000 RPM with 1:1 ratio at 1024 pre-quadrature ppr would be:
7000 /60 x 1024 x 4 = 478KHz
I don't particularly
like capacitive encoders like those but it should work. It appears they only have single ended outputs.
Message: 7439 |
Date: 5/6/2013 |
Subject: Re: Spindle encoder for rigid tapping |
Thanks Tom
I have a few US digital differentials around as well so I'll use one of them. What would be the minimum wheel count before quad you would recommend. I think 500 is as high as I go.
I can order a new disk but If I can use what I have it would be better.
Derek
> Hi Derek,
> KFLOP Encoder inputs are limited to 1MHz post-quadrature counts per second.Â
> I don't particularly like capacitive encoders like those but it should work. It appears they only have single ended outputs.
> From: tig415 <tig416@...>
> Sent: Monday, May 6, 2013 10:19 AM
> Subject: [DynoMotion] Spindle encoder for rigid tapping
> I'm setting up my mill for rigid tapping. I'm working out the encoder for the spindle. I'm running it with a timing belt and pulley arrangement. My max spindle speed is 7000 RPM.
> My question is are there any considerations to how fast I should drive the encoder? 1:1 or would I be better off reducing the speed of the encoder with the pulleys?
> I don't plan on tapping at 7000 rpm but it would be nice if the encoder was accurate at that speed :)
> The encoder I'm using is the AMT-102.
> http://www.cnc4pc.com/Store/osc/product_info.php?cPath=64_78&products_id=363
> Thanks
> Derek
Message: 7440 |
Date: 5/6/2013 |
Hi Derek,
I think 500 ppr (2000 quadrature counts/rev) should work.
